kann mit hier jemand helfen?
SQL Error 80040e14
Code: 80040e14
Code meaning: IDispatch error #3092
Source: Microsoft OLE DB Provider for SQL Server
Description: SQL Server encountered error 0x80070218 while communicating with full-text filter daemon host (FDHost) process. Make sure that the FDHost process is running. To re-start the FDHost process, run the sp_fulltext_service 'restart_all_fdhosts' command or restart the SQL Server instance.
Function: m_rs->Open
Command: SELECT TOP 500 arc.[path], msg.[srFilename], msg.[srSubject], msg.[srFrom], msg.[srTo], msg.[srDocType], msg.[srStatusTime], msg.[srRecNo], msg.[Send
User ID: 100e4000
